| so i decided to put the whole test with results to see if i can get more help so i held auto/off for 5 seconds this is what happened 24 ac did not come on display showed def then i started to click the angle switch where you want the air to blow. this is the results i got 98 arrow pointed toward you 75 arrow pointed to feet 68 def 53 arrow pointed you 59 arrow pointed to feet 34 def 76 arrow pointed you 11 arrow pointed to feet 0 def 53 arrow pointed you 62 arrow pointed to feet 30 def 27 arrow pointed you 99 arrow pointed to feet 2 arrow pointed you 51 arrow pointed to feet Then I clicked auto, then i clicked the angle switch where you want the air to blow. this is the results 48 def 29 def and the arrow pointed to your feet 12 arrow pointed to you, and arrow pointed to feet it went 1 and paused for second then it went to 0 the arrow ponted to you and the cold air came out pushed auto this is using the angle switch to control where you want the air to blow
2 3 6 7 9 11 12 15 16 18 20 21 24 25 27 29 30 33 34 36 this is the opposite direction useing the fan speed switch 0 -2 -3 -6 -7 -9 2 3 6 7 9 11 12 15 16 18 20 21 24 25 27 29 30 33 34 36 pushed auto, used the angle switch where you want the air to blow 0 Def with no fan display 50 arrow pointed to you with no fan display 50 arrow pointed to feet with no fan display 50 def with fan display 50 arrow pointed to you with fan display 50 arrow pointed to feet with fan display 50 def with fan display, and fan speed on 1
